CABird_UK
Dec 18, 2020Tutor
NAS 104 Plex to NAS214 Plex copy
Netgear NAS 104 Fireware 6.10.4 Netgear NAS 214 Fireware 6.10.4 Netgear 104 has Plex App installed and stored media. Netgear 214 has Plex app installed and the same file shares as NAS 104. ...
- Dec 18, 2020
CABird_UK wrote:
Is there a method to copy Plex media metadata (library database) from Netgear 104 to Netgear 214?
Yes, but it does require use of ssh. There is a thread here that gives some info: https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/Unable-to-access-PLEX-media-files-Permission-issue/m-p/1993588
If you don't want to copy through a PC, then you can create a temporary share, copy (or zip) the media library into the share, and then transfer that over with a backup job. Then copy/unzip on the RN214. If you choose to copy with ssh, then you should set up the temporary share to be owned by root/root - otherwise some file owners might end up incorrect.
I just rebuild the libraries myself - though that could be a a fair amount of work if you have a lot of stuff that isn't matched correctly.
Dec 18, 2020Guru - Experienced User
- CABird_UKDec 18, 2020Tutor
Thank you seems to be a consider amount of work.
