Martcart78
Mar 05, 2020Aspirant
Nas 3100 disconnectes after 10 mins
Please can someone help me. My nas 3100 will disconnect after 10 mins. It will do this when I transfer files or in idle. I have to restart the unit to get it working again. Then 10 minutes later it do...
Martcart78
I have the NAS rack 3100 hard wired into a unifi switch. I access it thought window 10. Not using a browser. I open up the NAS folder and start copying files over. Let's say 10 gb size. Half e way thought it will drop the connection. I then have to reboot the NAS. And start again. But if u leave it to idle I will go back to it let's say an hour later. The NAS is there but will not open.. So I have to restart NAS to use it. Thanks
Mar 05, 2020Guru - Experienced User
Is the PC using ethernet or WiFi?
- Martcart78Mar 05, 2020AspirantHard wired all wired. Dont use WiFi at all.
- StephenBMar 05, 2020Guru - Experienced User
Martcart78 wrote:
Hard wired all wired. Dont use WiFi at all.Ok. So that's not something I am seeing (though my main NAS is an RN526x, not a 3100).
What firmware are you running?
- SandsharkMar 06, 2020Sensei
If the logs don't give any clues, it may be useful to enable SSH and leave an SSH session open until you lose access. Then use TOP to see if any processes seem to have stopped or are taking 100% of CPU time. If you are not fa,iliare with what the normal processes look like in TOP, jusr take a peak at them before anything goes amiss. The main one to see is still running normally is readynasd. though BTRFS and SMB processes may also be important.
