nh19926
May 03, 2016Aspirant
NAS204 HD and CPU Temp
I purchased a NAS204 and I am using 2 WD Hard drives in it.... WD2001FFSX, 7200 rpm, 64mb cache, Red Drives @ 2TB each.
I am new to this NAS and slowly getting the hang of it. Seem to work well...
nh19926
I just read the specs on my NAS 204 and it claims it is using a 92 mm fan, and that the operating temp is suppose to be 32 deg to 104 F, or 0 to 40C....
Mine unit is NOT running at the temps indicated in the manual of my RN-204
Now I am worried even more.... Unit is working correctly, but do not like the high temps.... definitely want to change out fans for Noctua - will doing that void my warranty?
nh19926
Another note..... Tried to do a soft-power down (pushing the On/Off button 2 times) but it seems to never power down. Earlier in the week I had to finally just pull the power.
How long does it take for this RN204 to power down and shut off after pushing the power button 2x ?
