  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    Hi Dreko
    Unfortunately the JGS516PE doesn't support SNMP, if you are looking for an SNMP switch with PoE I would recommend our Smart or Managed switches.
    In 16-port PoE we already have two models that supports SNMP and POE:
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
    • Drekko's avatar
      Drekko
      Thanks for that info
      bit late now, I already bought the JGS516PE
      So that is a "unmanaged switch" ?
      Is the only way to monitor the tempreture is to log into the device itself?
      • DaneA's avatar
        DaneA
        Drekko,
        I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility.  Also, there is no option to have a console connection to the JGS516PE switch.
        DaneA
        NETGEAR Community Team
ProSupport for Business
