Drekko
Sep 02, 2017Aspirant
JGS516PE - SNMP support? Monitor Temps
hi Does this switch have SNMP ? I want to be able to monitor its tempretures remotely
XavierLL
Sep 03, 2017NETGEAR Employee Retired
Hi Dreko
Unfortunately the JGS516PE doesn't support SNMP, if you are looking for an SNMP switch with PoE I would recommend our Smart or Managed switches.
In 16-port PoE we already have two models that supports SNMP and POE:
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
- DrekkoSep 03, 2017Aspirant
Thanks for that info
bit late now, I already bought the JGS516PE
So that is a "unmanaged switch" ?
Is the only way to monitor the tempreture is to log into the device itself?
- DaneASep 04, 2017NETGEAR Employee Retired
I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility. Also, there is no option to have a console connection to the JGS516PE switch.
DaneA
NETGEAR Community Team
- DrekkoSep 04, 2017Aspirant
DaneA wrote:I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility. Also, there is no option to have a console connection to the JGS516PE switch.
DaneA
Damm
I guess a taping a thermometer to the switch is the only way to go lol
