craig_ng
Jul 16, 2016Follower
Does the JGS516PE Support 802.3ad Dynamic Link Aggregation?
Hello all,
Does the JGS516PE support 802.3ad dynamic link aggregation (LACP)?
Thanks in advance.
Hello craig_ng,
Welcome to the community!
The JGS516PE does have LAG support but only the static one. It does not support LACP as of the moment. You may look at the Smart Managed Switches which has LAG with LACP.
Let us know if you have more questions.
Thanks,
- JohnRoNETGEAR Employee Retired
Hello craig_ng,
Thanks,
Hi craig_ng,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
