craig_ng's avatar
craig_ng
Follower
Jul 16, 2016
Does the JGS516PE Support 802.3ad Dynamic Link Aggregation?
Hello all,   Does the JGS516PE support 802.3ad dynamic link aggregation (LACP)?   Thanks in advance.
  • JohnRo's avatar
    Jul 18, 2016
    Hello craig_ng,
    Welcome to the community!
    The JGS516PE does have LAG support but only the static one. It does not support LACP as of the moment. You may look at the Smart Managed Switches which has LAG with LACP.
    Let us know if you have more questions.
    Thanks,
