ngott
Sep 02, 2020Follower
JGS516PE PoE question
Hi,
I am looking for a switch that can let me enable/disable individual PoE ports when needed. Does this model: JGS516PE have that function? I tried searching for it but can't find any info on it, so would appreciate it if someone can answer or tell me where to find this info.
Thank you!
Welcome to our community! :)
Unfortunately, this Smart Managed Plus Switches does not support to enable/disable a POE. But our Smart Managed Switches do support it.
Please close the thread by clicking the "Accept as solution".
Thank you!
John
NETGEAR Community Team
1 Reply
- JohnC_VNETGEAR Employee Retired
Thank you!
John
