ngott
Sep 02, 2020Follower
JGS516PE PoE question
Hi, I am looking for a switch that can let me enable/disable individual PoE ports when needed. Does this model: JGS516PE have that function? I tried searching for it but can't find any info on it...
- Sep 02, 2020
Welcome to our community! :)
Unfortunately, this Smart Managed Plus Switches does not support to enable/disable a POE. But our Smart Managed Switches do support it.
Please close the thread by clicking the "Accept as solution".
Thank you!
John
NETGEAR Community Team
JohnC_V
Sep 02, 2020NETGEAR Employee Retired
Thank you!
John
