Drekko
Sep 02, 2017Aspirant
JGS516PE - SNMP support? Monitor Temps
hi Does this switch have SNMP ? I want to be able to monitor its tempretures remotely
Drekko
Sep 03, 2017Aspirant
Thanks for that info
bit late now, I already bought the JGS516PE
So that is a "unmanaged switch" ?
Is the only way to monitor the tempreture is to log into the device itself?
DaneA
Sep 04, 2017NETGEAR Employee Retired
I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility. Also, there is no option to have a console connection to the JGS516PE switch.
DaneA
NETGEAR Community Team
- DrekkoSep 04, 2017Aspirant
DaneA wrote:I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility. Also, there is no option to have a console connection to the JGS516PE switch.
DaneA
Damm
I guess a taping a thermometer to the switch is the only way to go lol
- DaneASep 05, 2017NETGEAR Employee Retired
You may want to post your concern as feature request on the Idea Exhcange for Business board here. In this way, the development team can see what feature does users like you wanted to be added to the functionality of the JGS516PE.
DaneA
- DrekkoSep 05, 2017Aspirant
DaneA wrote:You may want to post your concern as feature request on the Idea Exhcange for Business board here. In this way, the development team can see what feature does users like you wanted to be added to the functionality of the JGS516PE.
DaneA
Will do but in saying that is it possible to add snmp support in a firmware update? If not id just have to buy the GS series which I do not want to do that
