Bronzestar
Mar 02, 2016Follower
Need a manual for an RNDP 6350 - 100 NAS. Suuport Downloads doesn't recocgnize the Model.
I inherited this RNDP 6350. It will not turn on. It may be the power supply which is an SS 300 SFD. I don't want to buy a new Power Supply only to find out that it is something else, that I would hav...
- Mar 02, 2016
That is a ReadyNAS Pro Business Edition that shipped with 3x500GB disks.
The hardware in the Pro 6 (RNDP6000-200) is very similar. Indeed if you look at the Hardware Manual you can see that it also covers the earlier Pro models.
There are suggestions on the community as to what replacement PSUs you could use.
mdgm-ntgr
Mar 02, 2016NETGEAR Employee Retired
VailComputerGuy
Mar 03, 2016Initiate
Thank you so much!
Indeed, chapter 4 of the manual is for the RNDP6350-100NAS !
Sometimes I get caught up in how easy things usually are to find and I forget to dig a little deeper!
