lwarner
Oct 29, 2011Aspirant
Need a new Fan
After about 6 years and multiple cleanings, the Fan in my Infrant ReadyNAS NV is on it's way out. The question is "how do I find the correct replacement fan?" Data: ADDA Corp DC Brushless Model...
lwarner
Nov 01, 2011Aspirant
Thanks for the feedback. Since my post, I went to the fan manufacturer's web site ADDA at http://www.addausa.com/TECHNICAL%20SUPPORT.htm Their distributor Mouser at Mouser.com has the exact model number for $13.85. Should be here Friday so I'll see if it is exact.
Presently I'm dealing with two drives showing increasing bad sector counts. I replaced one yesterday and it is resyncing. Fortunately both are under warranty and I should have the replacements in two days from Seagate. I'm running Seagate ST32000542AS 2TB drives. I hope this isn't an indication of marginal drives. One of the failing drives was new just a month ago. The NAS is 5 years old now and maybe it's time to look at replacements.
Thanks again,
Larry Nuke
Thanks again,
Larry Nuke
