immagikman
Mar 18, 2014Aspirant
Need a solution for 60TB+
What I want to do is eventually have about 60TB or more of DVD and BluRay ISO images online for my media server. Currently Im using a ReadyNAS Pro 6 and a ReadyNAS Ultra 6 each loaded with 3TB drive...
Mar 26, 2014Guru - Experienced User
Also keep in mind that this class of equipment is usually very noisy - and the noise level is not spec'd since it isn't intended for home installations. So you should make sure you have a location for it where the noise doesn't matter.
