Oolong666
Feb 02, 2014Aspirant
Need Help with reset/resync issues
I have a ReadyNas NV+ with firmware RAIDiator 4.1.13 and 4X WD 2T drives. My system keeps resetting and indicating that a RAID event has occurred "Access to the disk on channel (??) is producing I/O ...
vandermerwe
Feb 02, 2014Master
I would power down the NAS and test each disk using western digital lifeguard
http://support.wd.com/product/download. ... =3&lang=en
Don't remove drives or reinsert them with the NAS on and remember to label them with slot number if you take them all out.
Run the extended test, which takes a long time ( over 12 hours per disk) as the short test doesn't always reveal a problem.
If the NAS is not indicating anything in the error message then I suspect the logs won't be useful.
Is the smart data OK?
I assume you don't have a backup?
