MarcStengel
Jun 26, 2023Follower
Need to replace RN31400
My RN31400 just stopped working and will not turn on. Is there a new NAS I can buy so I can just take my old drives and put it in the new NAS and see all my old data?
Jun 27, 2023Guru - Experienced User
Most likely a power adapter failure. So I suggest doing a risk-buy of a compatible replacement.
A couple I am seeing on-line are
- https://www.amazon.com/332-10781-01-2ABP084F-Power-Adapter-ReadyNAS/dp/B0853DQQ76
- https://www.amazon.com/ABLEGRID-RN31441E-100NAS-RN31442E-100NAS-RN31443D-100NAS-RN31442D-100NAS/dp/B0716LFR7Q/
Note the RN312 adapter is 60 watts (5 amps), while the RN314 is 7 amps. Ideally purchase a replacement that says it is at least 7 amps. Some don't say (regrettable), so at least make sure it includes the RN314, and not just the RN312 (or RN1xx/RN2xx).
I doubt you'll find any new readynas out there. But you could get a used one. RN300/RN400/RN520/RN626 are all x86 OS-6 NAS, and you can directly migrate to any of these systems with 4 or more bays.
RN100/RN200 NAS would also work, although they are ARM. The RN200 is a better option than the older RN100.
Older Pro and Ultra models can be converted to OS-6, and after that you could migrate the disks. But keep in mind that Netgear discontinued them 10 years ago,
