JohnSwede
May 11, 2019Aspirant
Need to update ReadyNAS ultra 2 due to SMB1 vulnerability!
Hi everyone!
I'm planning to use my old NAS again but because of security issues with SMB1 I find that microsoft have rendered it useless, which ofcourse is a good thing! I have tried to find a gui...
- May 12, 2019
There's no need for ssh. You should be able to just install that bios package as an add-on in the web ui. After that reboot. Your bios should then be 11/02/2011 ReadyNAS-ProUltra2 V1.8
JohnSwede wrote:
My software --- RAIDiator!!version=4.2.30 --- upgrade using PREPR4TOR6_0.1-x86.bin
That's just the first step. The full process is here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-3100-Maximum-HDD-size/m-p/1664134#M151232
May 12, 2019Guru - Experienced User
- JohnSwedeMay 12, 2019AspirantThat simple eh, I'm officially embarrasedđ! Looked like it worked, system is starting again after what I believe is a format of my drives. I can't thank you enough mate, have a nice dayđ
