RUFUSREDTAIL's avatar
RUFUSREDTAIL
Net Gear RND 4000 V 3
I have windows 11 cannot access the device comes up with this message 10.0.0.234 uses an unsupported protocol . any help to  recitfy this problem please , previously has windows 10 same problem , some time ago was able to access now this message keeps coming up .
  • StephenB's avatar
    Yeah.  Your legacy NAS only supports TLS 1.0, and modern browsers are starting to drop support for that.
    Options include
    • using IE (or Edge in IE mode) if windows 11 supports that.
    • Downloading an old version of Firefox (94.0.2 will work), and connect with that.  Make sure you immediately change the browser settings to disable auto-update
    • Modify a config file in the NV+ using SSH, which will let you connect with unencrypted HTTP.
    There's a thread that includes info on the config file option here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
    Note you have a sparc-based NAS (called a v1 here).  The v2 add-on referenced in the other thread is not compatible with your NAS.
ProSupport for Business
