ksor1
Jun 26, 2025Aspirant
Netgear DUO admin site ??
I've had this NASdrive for years and it has worked well - I renewed the discs 1 time - nice ! I had it running under Windows 10 for most of the years - but had the problem that I could NOT get ac...
- Jun 26, 2025
ksor1 wrote:
I sometimes just run the RAIDAR program
It'd be helpful to know if you have the original Duo, or if you have the Duo v2.
The original Duo
- says ReadyNAS Duo on the front panel and in RAIDar
- runs 4.1.x firmware (RAIDar should tell you that)
The v2
- says ReadyNAS Duo v2 on the front panel and in RAIDar
- runs 5.3.x firmware
ksor1 wrote:
the NAS is still assigned 192.168.1.2
Then you can access the NAS web ui using https://192.168.1.2/admin. But you need to use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
If you don't recall the admin password, the default for the original Duo is netgear1. The default for the v2 is password.
ksor1 wrote:
I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days
It'll be easier to sort this out after you get admin access.
Jun 26, 2025Guru - Experienced User
ksor1 wrote:I remember I had never had access to the administrator site before !
You should have (and you should log in as admin from time to time to make sure the NAS is still operationing correctly).
ksor1 wrote:but after resetting the network it wont work
Let's start here.
- What exactly did you do to "reset the network"?
- Is the network still using 192.168.1.x addresses?
- Is the NAS still assigned address 192.168.1.2?
- ksor1Jun 26, 2025Aspirant
THX for a very quick reply StephenB !
I can't remember when my access to the admin site stopped ... I sometimes just run the RAIDAR program to see if the NAS is still OK.
I'll answer you Q's here:
add 1) I just used the Windows key for resetting the network.
add 2) My router is set up as DHCP server to manage the pc's in the network and too the NAS
add 3) Yeah the NAS is still assigned 192.168.1.2 and I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days until I used the reset network key in Windows 11
I used the reset network key hoping it could solve the problems I have with the security settings to get macros to work in Excel/Word ... they are driving my in sane /&%(/(/%/&%¤%&%%#¤ !
I would be very happy if you could help me get my head around these NAS problems :-)
- StephenBJun 26, 2025Guru - Experienced User
The original Duo
The v2
Again THX for your time to help me out of this mess !
I will find out what you asks for and come back !
THX
