ksor1
Jun 26, 2025Aspirant
Netgear DUO admin site ??
I've had this NASdrive for years and it has worked well - I renewed the discs 1 time - nice ! I had it running under Windows 10 for most of the years - but had the problem that I could NOT get ac...
- Jun 26, 2025
ksor1 wrote:
I sometimes just run the RAIDAR program
It'd be helpful to know if you have the original Duo, or if you have the Duo v2.
The original Duo
- says ReadyNAS Duo on the front panel and in RAIDar
- runs 4.1.x firmware (RAIDar should tell you that)
The v2
- says ReadyNAS Duo v2 on the front panel and in RAIDar
- runs 5.3.x firmware
ksor1 wrote:
the NAS is still assigned 192.168.1.2
Then you can access the NAS web ui using https://192.168.1.2/admin. But you need to use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
If you don't recall the admin password, the default for the original Duo is netgear1. The default for the v2 is password.
ksor1 wrote:
I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days
It'll be easier to sort this out after you get admin access.
schumaku
Jun 26, 2025Guru - Experienced User
To access such a legacy NAS, following a complete Windows network reset might require re-adding the ip optional SMB 1.0/CIFS protocol as have in not a part of the default Windows 11 network config. Head to Windows Features, and re-adding the optional SMB 1.0/CIFS support again (both client and server).
A reason why you have to use authentication is because a modern Windows 11 system does. I longer allow anonymous (aka. guest) access, even as a client.
Welcome to the modern world of Windows 11.
