ksor1
Jun 26, 2025Aspirant
Netgear DUO admin site ??
I've had this NASdrive for years and it has worked well - I renewed the discs 1 time - nice ! I had it running under Windows 10 for most of the years - but had the problem that I could NOT get ac...
- Jun 26, 2025
ksor1 wrote:
I sometimes just run the RAIDAR program
It'd be helpful to know if you have the original Duo, or if you have the Duo v2.
The original Duo
- says ReadyNAS Duo on the front panel and in RAIDar
- runs 4.1.x firmware (RAIDar should tell you that)
The v2
- says ReadyNAS Duo v2 on the front panel and in RAIDar
- runs 5.3.x firmware
ksor1 wrote:
the NAS is still assigned 192.168.1.2
Then you can access the NAS web ui using https://192.168.1.2/admin. But you need to use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
If you don't recall the admin password, the default for the original Duo is netgear1. The default for the v2 is password.
ksor1 wrote:
I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days
It'll be easier to sort this out after you get admin access.
ksor1
THX for a very quick reply StephenB !
I can't remember when my access to the admin site stopped ... I sometimes just run the RAIDAR program to see if the NAS is still OK.
I'll answer you Q's here:
add 1) I just used the Windows key for resetting the network.
add 2) My router is set up as DHCP server to manage the pc's in the network and too the NAS
add 3) Yeah the NAS is still assigned 192.168.1.2 and I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days until I used the reset network key in Windows 11
I used the reset network key hoping it could solve the problems I have with the security settings to get macros to work in Excel/Word ... they are driving my in sane /&%(/(/%/&%¤%&%%#¤ !
I would be very happy if you could help me get my head around these NAS problems :-)
Jun 26, 2025Guru - Experienced User
ksor1 wrote:I sometimes just run the RAIDAR program
The original Duo
The v2
ksor1 wrote:the NAS is still assigned 192.168.1.2
ksor1 wrote:I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days
- ksor1Jun 26, 2025Aspirant
Again THX for your time to help me out of this mess !
I will find out what you asks for and come back !
THX
Oh, I forgot - I think I'll do the 'work to fix it' on the Windows 10 machine - eventhough it' my 'go to machine' and life line to the world !!!!
- ksor1Jun 27, 2025Aspirant
THX
Here I am again with goog news for me - I hope !
It’s an original ReadyNAS DUO, firmware 4.1.16
I got into the admin site and her is a copy of the front (the first) to show up:
Hostname:
nas-72-89-FD
Model:
ReadyNAS Duo [X-RAID]
Serial:
24M4137H00969
Firmware:
RAIDiator 4.1.16 [1.00a043]
Memory:
256 MB [2.5-3-3-7]
IPv4 address::
192.168.1.2
Volume C:
Online, X-RAID, 2 disks, 30% of 1846 GB used
- StephenBJun 27, 2025Guru - Experienced User
ksor1 wrote:
Here I am again with good news for me - I hope !
It’s an original ReadyNAS DUO, firmware 4.1.16Great. The simplest way to access the admin web ui is to stick with FireFox (and that setting change). There is one other way -modifying the NAS to allow you to use http (unencrypted) instead of https. But that does require use of the linux command line. Is that somethings you have experience with?
ksor1 wrote:
now it asks for credentials to get access !!!!
There are a couple of things to check here.
The first is to go into "Turn Windows Features on or off" and make sure that the SMB 1/CIFS client is enabled.
As schumaku says, the other thing we need to change is to not use guest access to access the NAS.
To do that you need to either tell Windows to use the NAS admin account, or create a new user account on the NAS. Both will work, but the new user account is a bit safer. You could (for example) create a new user account called Duo, and create a password for it. Although this screenshot is from a different firmware branch, I think your NAS has the same screen:
Either way, you then need to create a windows credential for the NAS in the Windows Credential manager.
Enter the credential for the IP address, using your NAS account name (admin, or the new account you created), and the password for that account.
I don't know for sure if "Media" is a share on your NAS. So enter \\192.168.1.2 in the address bar of File Explorer after you done these steps. You should then see a list of your shares in File Explorer, and you should be able to browse them. Be careful to use the correct slash (\\, not //).
Hi StephenB again !
I thank you for your very nice answers and explanation - very nice !
I'll answer in two steps - 1) what I have done so fare, 2) manage your new proposals.
1)
On the W10 machine in Firefox I did these configirations and got the access, tried my credentials and it worked. I the changed the configuration back again to level 3.
All on my W10 machine worked (as it did before) !The I tried to access the NAS from the W11 machine and it still wants my credentials, I entered them and off it goes - I can see my files on the NAS from the W11 machine - also after reboots.
IF I wants to do any thing at the admin site I'll have to do the config changes - did I get it right ?
To me it would be suficient and acceptable, BUT .... and now to your proposals
2)
In the longer run I plan to upgrade to W11 on all my machines and use Edge ... but right now Edge wont access the NAS because of un-supported protocol ... and I don't know if it's posible to make the needed config changes to solve that.
But I could have installed Firefox IF I SHOULD NEED to access the admin on the NAS :-)
I understand I'm using the ReadyNAS as a GUEST and then it's an unsafe practice - did I get it right ?
IF SO I'll try to create a new user on the NAS ... but go slow because the whole family use this daily and I'l be stoned out of town if the can't use it for days :-(
Again THX for your time and very nice answers !
Best from
Keld in Denmark
