ksor1
Jun 26, 2025Aspirant
Netgear DUO admin site ??
I've had this NASdrive for years and it has worked well - I renewed the discs 1 time - nice ! I had it running under Windows 10 for most of the years - but had the problem that I could NOT get ac...
- Jun 26, 2025
ksor1 wrote:
I sometimes just run the RAIDAR program
It'd be helpful to know if you have the original Duo, or if you have the Duo v2.
The original Duo
- says ReadyNAS Duo on the front panel and in RAIDar
- runs 4.1.x firmware (RAIDar should tell you that)
The v2
- says ReadyNAS Duo v2 on the front panel and in RAIDar
- runs 5.3.x firmware
ksor1 wrote:
the NAS is still assigned 192.168.1.2
Then you can access the NAS web ui using https://192.168.1.2/admin. But you need to use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
If you don't recall the admin password, the default for the original Duo is netgear1. The default for the v2 is password.
ksor1 wrote:
I used the 'name' \\192.168.1.2\media" to get access in Windows 11 ... and in fact it worked for 3-4 days
It'll be easier to sort this out after you get admin access.
Jun 28, 2025Guru - Experienced User
ksor1 wrote:Linux command line interface ... no experience but I have tried to run a mashine once in my younger days but left it because of ' too many 'do it youself details' - buit it sounds interesting if I could use Edge ... that's my plan IF I manage to install W11 on more of my machines - if it's not TOO complicated and if you can just pull it out of your sleaves then I would be very happy :-)
See the first post here:
This post gives a step-by-step that doesn't require much linux experience:
- https://community.netgear.com/discussions/readynas-general/workaround-for-err-ssl-version-or-cipher-mismatch-problem-for-sparc-nas-4-1-x-fi/2198243/replies/2202466
ksor1
Jun 28, 2025Aspirant
Oh, so nice ... I'll study the links and report back after some days !
THX !
