toms1
Jun 16, 2012Aspirant
Netgear falling behind?
I've been a long time ReadyNas user, I currently own two Duos and am getting ready to upgrade to a single 6 bay unit. To my disappointment ReadyNAS does not seem to be keeping up. The higher end uni...
PapaBear1
Jul 11, 2012Apprentice
Of course if you had bothered to look at the HCL, you would have noted the Samsung F4 2TB drives and the F3 2TB predecessor. There is no memory HCL because manufacturers were changing the module components without changing the model number. So older versions of a model number worked and newer ones did not. Then WD did the same thing on hard drives, but stopped doing that.
