b4pjoe
Jan 09, 2024Aspirant
Netgear ReadyNAS 104 won't power up.
On Sunday at 3:15 pm I got an email notification that reads "Detected high spin retry count: [262144] on disk 1 (Internal) [TOSHIBA DT01ACA200, Y2S3T8DAS]. This condition often indicates an impendin...
- Jan 16, 2024
I decided to risk the $26 for the new power supply. Got it today and it started right up with the new power supply so case is solved. Bad power supply.
Jan 09, 2024Guru - Experienced User
b4pjoe wrote:
I didn't see these notifications until later Sunday evening and when I checked the NAS with the errors it was powered off and would not power back on so I left it until Monday morning and then unplugged the power cord for about 5 minutes. Re-attached the power cord and plugged in in. The unit powered back up and booted with no errors. After about 5 minutes I powered it off and moved it back to its proper location. Then it again would not power back up. I removed the drives and it still would not power back up. No luck so now it seems to be dead.
You might try doing a risk-buy of the power adapter, and see if that brings it back to life.
You might also get an inexpensive dock that supplies its own power (not powered over USB). Then try one disk at a time, and see if the disk is found Windows won't recognize the format, but the disk manager will see it. You can also try Toshiba's utility here:
I agree you should be cautious about moving all the disks to another NAS.
