itsgbp
Feb 25, 2026Follower
Netgear ReadyNAS 3312 Not Booting
I am using a Netgear ReadyNAS 3312 (12-bay model). After rebooting the NAS, it powered on but is not responding to ping. The power LED (blue) and Network LED (yellow) are continuously blinking. ...
Feb 26, 2026Guru - Experienced User
itsgbp wrote:I am using a Netgear ReadyNAS 3312 (12-bay model). After rebooting the NAS, it powered on but is not responding to ping.
Does it respond when you power down, remove the disks, and then power up again? Label the disks as you remove them, so you can return them to the proper slots. (Also, when you do return them, make sure the NAS is powered down).
