soiraipur's avatar
soiraipur
Follower
May 28, 2025
Netgear ReadyNAS 4312V2
Hello Team,
We are facing to access my shared folder.
and need your support for the same.
  • StephenB's avatar
    Note this is a user-to-user forum.  All ReadyNAS models are end-of-life, so there is no Netgear support for them.
    We need a lot more details on your problem.  For instance,
    • Is this a home folder or a share?
    • What error are you getting?
    • Are you seeing any errors in the NAS web ui (or the log zip)?
    • What device are you using to access the folder?
    • Is this happening to other users or other shared folders?
    • Did something change that might have triggered the problem (for instance, a windows 11 upgrade)?
    • Sandshark's avatar
      Sandshark
      Sensei
      And is the NAS AD integrated, or are you using NAS-only credentials?
ProSupport for Business
