Nummerskivan
Feb 15, 2012Aspirant
Netgear ReadyNAS Duo RND2110 1TB (and a q about Stora)
Hi! I can't find the MHz for this NAS. On the price comparizing site it says 280 MHZ, but the seller site says 1 600 MHz. What is correct?
Nummerskivan
Thanks. It was listed as just Duo, but beneath it, Duo v2 was listed. So I guess it is 280 then, and that the seller has either wrong numbers, or it is a v2. I will for sure check that out before buying.
I have another question. I was also looking at Netgear Stora MS2110 1TB and found it has two disks so I do not have to buy one extra. This makes it really much cheaper than the ReadyNAS Duo (v1 or v2).
But what is the downsides with a Netgear Stora MS2110 1TB compared to the two Duo ones? My price comparing site lists a lot of features and specs, but lacks very much from these. I can see though, that people in general gave the duo v1 8 of 10 stars, and the Stora 7 of 10 stars.
