Nummerskivan
Feb 15, 2012Aspirant
Netgear ReadyNAS Duo RND2110 1TB (and a q about Stora)
Hi! I can't find the MHz for this NAS. On the price comparizing site it says 280 MHZ, but the seller site says 1 600 MHz. What is correct?
mdgm-ntgr
Feb 15, 2012NETGEAR Employee Retired
The Stora is a completely separate product. If you later decide you need more drive bays you can't migrate disks from a Stora to a ReadyNAS.
With a Duo v1 you can migrate to a NV+ v1, or with a Duo v2 you can migrate to a NV+ v2.
