mekm
Jun 14, 2012Aspirant
Netgear ReadyNAS Duo RND2150 Memory Compatibility List?
Hi All, The compatibility list seems to be unavailable? I'm looking at updating the memory on my Netgear ReadyNAS Duo RND2150 to 2GB. Would like to check memory is compatible would buy from e...
RGray02
Jul 23, 2012Aspirant
The old school Duo v1 will only accept up to 1 GB of memory upgrade. I bought a 1GB PC2700 Crucial stick a while back when they had the HCL up. Its worked fine for 2 years. I'm replacing the unit, and as I mentioned in another thread I'd be willing to part with it.
If you are interested email me at gunnar1979 at yahoo dot com
