Elvis439
Mar 21, 2018Aspirant
Netgear ReadyNas Duo V2 damage
Hello, please tell me what can i do to finish with my problem. My ReadyNas Duo V2 show: The main folder is damaged. I've gór very important data on this ReadyNas. Please help me!
Elvis439
This is picture. It's Polish versiofoto
- StephenBMar 21, 2018Guru - Experienced User
Thanks. I am thinking the translation is flawed (that the English version would say something different). Corrupt Root perhaps??? Perhaps mdgm-ntgr can track it down.
If you have a USB dock, you could power down the NAS and then connect the disk to a Windows PC. Then see if R-linux for Windows can access your files ( http://www.r-tt.com/free_linux_recovery/ ).
If it can't, then you will either need paid support (my.netgear.com) or RAID recovery software. Several users have reported success with ReclaiMe.
- Dec 28, 2018Retired_Member
