JamesHorton
Jun 17, 2022Guide
Netgear ReadyNAS NV+ (RND4000 V3) has died
Hi, everyone I was hoping for some advice, please. My Netgear ReadyNAS NV+ (RND4000 V3) has died. It fails to switch on and boot. I've checked the PCU which is dead. I believe it is beyond the cos...
JamesHorton
Jun 28, 2022Guide
Firefox 94.0.2 release appears not to work for me also? I'm on a mac if that makes any difference?
I think I'll check my network settings. As I only can connect via wifi. Very odd.
Thanks,
James
JamesHorton
Jun 28, 2022Guide
Sorted. Netgear default password. Using Opera, to gain access to Frontview. It may work in other browsers? I would have to try them next.
Thanks, everyone.
Kindest Regards
James
