thecaver99
Dec 01, 2021Aspirant
Netgear RN10200 firmware update communication error
I have an rn10200 its on firmware 6.10.5 hotfix 1 and im trying to update to the latest 6.10.6 but all i get is a communications error when i try and do a manual update. if i do an automattic upda...
Dec 01, 2021Guru - Experienced User
Weird. I didn't see that when I updated my own RN102 a few weeks back.
- Did you extract the img file from the zip?
- Any sign that the OS partition is full?
thecaver99
Hi thanks for replying
No the drive is newly formatted and nothing put on at the moment its completely blank
- StephenBDec 02, 2021Guru - Experienced User
thecaver99 wrote:
No the drive is newly formatted and nothing put on at the moment its completely blankNote the OS partition is different from the data volume.
But if the NAS has no data, maybe try doing a factory default from the system->settings menu - which will reformat the disk(s), and reinstall the OS from the flash. Then see if the update works normally.
