thecaver99
Dec 01, 2021Aspirant
Netgear RN10200 firmware update communication error
I have an rn10200 its on firmware 6.10.5 hotfix 1 and im trying to update to the latest 6.10.6 but all i get is a communications error when i try and do a manual update. if i do an automattic upda...
thecaver99
Hi thanks for replying
No the drive is newly formatted and nothing put on at the moment its completely blank
Dec 02, 2021Guru - Experienced User
Note the OS partition is different from the data volume.
But if the NAS has no data, maybe try doing a factory default from the system->settings menu - which will reformat the disk(s), and reinstall the OS from the flash. Then see if the update works normally.
