bruceread
May 05, 2020Aspirant
Network Credentials External Drive on ReadyNAS 102
I have a ReadyNAS 102 with an external hard drive plugged into one of the back USB ports. The drive is visible within Windows File Explorer in the list of ReadNAS folders. When I click on the externa...
May 05, 2020Guru - Experienced User
I'm not seeing your screenshots.
Perhaps look at the share settings (both network access and file access) for the USB drive share, and compare them with the settings you see on the shares you can access.
