rodcrit
Nov 11, 2021Luminary
network disabled
help!!! I have inadvertently disabled my network interface on my NAS system. it is no longer on my home network and cannot access it.
I noticed from another similar incident reported that part of a solution was :
Failing that you need to perform a Boot Menu OS Re-install (NOT FACTORY DEFAULT) following which your password will revert back to the default of "password"
I have no idea of how to do this.... at the moment I have no way of accessing the NAS system. can anyone give me a simple guide how to do it?
my computer skills are very old and I am rather old so it needs to be very simple.
thanks
Rodcrit
Ha! solved. plugged my network cable into the other ethernet port and was able to access system - and could enable to other port which I has disbabled :-)
learn something new every day - even at 80 years old
1 Reply
- rodcritLuminary
