MFallone
Oct 07, 2023Aspirant
Network novice trying to access ReadyNAS NV+ // Help?
Hello all. I'm a total network novice. I have a ReadyNAS NV+ that is connected to my iMac via ethernet. I have installed RAIDar - which quickly detects the ReadyNAS. When clicking on RAIDar's Admin P...
MFallone
Hello and thank you very much StephenB . I rebooted and still get the same IP address. i haven't started this ReadyNAS up in about 2 years.
Sandshark
Oct 07, 2023Sensei
Don't connect it directly to the computer, put it on your network by plugging it into your router or switch. If there is some reason you can't do that, then you'll have to manually assign a compatible IP address to the computer, one in the 192.168.168.xxx range.
But then you're also going to have to work around the fact that the NAS uses SMB1 and TLS V1.0. You can work around the TLS issue by using FireFox and changing the appropriate setting. But I'm not sure how you work around SMB1 with a Mac.
