jasonbb's avatar
jasonbb
Tutor
Jan 12, 2017
New bigger disk in ReadyNas Duo V2
Hi guys, I have the Duo V2 and it had 2 x 2TB WD red drives installed, it's in X-RAID2, the second drive failed so I bought a 4TB WD red drive, I swapped the 2nd drive with the new 4TB drive and the ...
  • FramerV's avatar
    Jan 14, 2017
    Hi jasonbb,
    X-RAID2 can only expand volumes when redundant space can be added. You will need to replace the other 2TB disk with a 4TB.
ProSupport for Business
