metulmark
Aug 15, 2011Aspirant
new caviar green 2tb earsx
hi is the new western digital caviar green model earsx compatable with the nas duo ultra 2? this is the direct replacement for the ears model thanks mark
PapaBear1
Aug 15, 2011Apprentice
The problem is that WD has had a nasty habit of changing their drives and not changing the model number. The WD20EARS was a case in point. Originally it had four 500GB platter, then 3 666GB platters and with and without TLER.
What are the changes that WD made going from a WD20EARS to a WD20EARSX? Sometimes drive and operating system manufacturers make changes to "improve performance" that upset their compatibility with RAID. If for example you were running RAIDiator 4.2.16 and had a Mac running Snow Leopard and had time machine set up, upgrading to Lion would break the time machine configuration on the NAS. Netgear has a beta of a new version of RAIDiator to fix that. They have to take the drives and test them in various configurations and situations before they can be approved.
