PBC
Sep 03, 2011Aspirant
New disks for my ReadyNAS NV
I am needing to replace one of my failed Seagate Barracuda 500GB, so thought I would move to some high capacities. Can anyone tell me if this model is compatible with my old NV ? Seagate ST31000...
mdgm-ntgr
Sep 04, 2011NETGEAR Employee Retired
Seeing that the HD204UI is a 4k sector disk, I would suggest you backup your data, upgrade to the latest RAIDiator (should be 4.1.8 by the time you get to this as this will hopefully be released within a few days or so) and do a factory reset, then restore data from backup.
See Why you might want to factory reset a Sparc ReadyNAS
