XrayDoc88
Dec 18, 2017Apprentice
New Install. Where's PLEX?
I'm trying not to panic, but one of the main reasons I just purchased a ReadyNAS was to run a PLEX server. In my prepurchase research I had read many posts about people using PLEX on their ReadyNAS....
- Dec 18, 2017
At plex.tv/downloads you download Plex Media Server choosing the NETGEAR Intel 6.x Package. You then go to the Apps tab of the ReadyNAS web admin GUI, click on the Upload button and browse for the .deb file you just downloaded.
XrayDoc88
Thanks for the reassuring, quick response. Since I'm actually completely new to using PLEX, maybe you'd know the answer to a couple questions I have?
1. What is the advantage of having PLEX installed on your NAS as opposed to just having PLEX installed on a network computer that then accesses your NAS video folder?
2. If you stream an HD movie from your NAS to a smart phone or other device, can PLEX or the NAS transcode on the fly if the device doesn't have adequate bandwidth or needs a lower resolution video stream?
Thanks again.
dschwartzer
Dec 18, 2017Luminary
In response to your questions:
The advantage to installing Plex on your ReadyNAS is that your computer does not have to be on all the time. With Plex running on your server, your content will always be available. In addition, other people can have access to the content without accessing your computer.
Although I use Plex I am far from an expert on how it works. That said, Plex does handle transcoding of media as long as your hardware can support it. I think that with your 626X, you should have no trouble with transcoding. Also, Plex needs extra hard disk space to temporarily store the transcoded files so you need to make sure you have sufficient space to support the transcoded files.
Hope that helps.
Davi
- StephenBDec 18, 2017Guru - Experienced User
FWIW, I've chosen to run a windows application server, with the media stored on the NAS. The NAS data volume is mapped to a PC drive letter.
My reasons are
- Often native Windows applications are more capable than their Linux equivalents (and in some cases linux versions are not available are all). Though that is not the case with plex, the Linux version has the same features as the Windows version.
- The NAS memory is limited (though more than enough for file serving)
- Sometimes installed NAS applications block your ability to update the NAS firmware.
- Separating the two functions makes it simpler to upgrade either to newer platforms.
This is not to say that it's a bad idea to run plex and other apps on the NAS. Just that there is a tradeoff, and it's reasonable to choose not to.
It is true that you need to keep a PC application server running 24x7 if you want your content to be always available.
I don't get the last sentence - there's no difference in remote access to plex. One way or another remote users are accessing the plex server, whether it runs on a dedicated application server or on the NAS itself.
The RN600 series has no difficulty transcoding HD, but it will have trouble transcoding 4K. So will most PCs.
Plex can transcode on-the-fly, so any extra disk space is inconsequential. It can also do off-line conversion (creating a lower quality but smaller file for streaming), which of course will take disk space.
- mdgm-ntgrDec 18, 2017NETGEAR Employee Retired
Personally I run Plex Media Server on my NAS. It works great for me.
- StephenBDec 19, 2017Guru - Experienced User
I have in the past, and I agree that both approaches work for plex. Hardware accelerated streaming would require a PC, since there is no GPU in the NAS.
Crashplan on the other hand has worked out better on the PC (partly because it needs a lot of memory, partly because it avoids the need for the headless install). iTunes does too, since you can use the full-featured Apple version, instead of the limited reverse-engineered open source.
- XrayDoc88Dec 18, 2017ApprenticeGreat information! Thank you. So how do you actually install Plex? I went to the download site. It doesn't appear to be an exe file.
