Nobuddy
Dec 08, 2014Aspirant
New ReadyNAS compatible with older/smaller drives?
I currently own two NV+ and having upgraded the size of the hard drives over the years. I was looking into purchasing a ReadyNAS 104 to make use of the older drives (750 GB) that no longer reside in t...
RX
Dec 08, 2014Luminary
I believe you cannot use your old 750 GB drives from your old ReadyNAS NV+ to the RN104 which is a ReadyNAS OS 6 model. It would be best that you follow the compatibility list of hard drives for the respective ReadyNAS model.
