Nobuddy
Dec 08, 2014Aspirant
New ReadyNAS compatible with older/smaller drives?
I currently own two NV+ and having upgraded the size of the hard drives over the years. I was looking into purchasing a ReadyNAS 104 to make use of the older drives (750 GB) that no longer reside in t...
Dec 08, 2014Guru - Experienced User
There is at least one SSD on the HCL that is smaller than 1 TB, so it is clearly not an OS restriction.
If you use a drive that is not on the HCL, then Netgear will deny support.
