Kinne
Jul 14, 2011Aspirant
[new] RN12T1230 (36TB)
Hi, it seems Readynas RN12T1230 with 36TB will be available, soon. But what about its specifications? - Dual PSU? - 10 Gbit/s slots? - which harddrives? 7200rpm? - throughput in different RA...
mdgm-ntgr
Jul 14, 2011NETGEAR Employee Retired
Well assuming such a product is coming I expect it would probably be very similar to the existing 4200 models. Until/Unless NetGear officially announces such a product they likely won't comment on it.
One can make some guesses:
Dual PSU - Can't see why it wouldn't have this. Dual hot-swappable PSUs is a key high-availability feature of he 4200.
10 Gbit slots - It'll probably have the same optional dual-NIC 10Gbit PCIe options
Which hard drives? - Enterprise 7200 rpm hard drives, of course. Reliability and performance are key. Most likely disks on the compatibility list for the 3100.
Throughput - should be at least as good as current 4200. I don't know whether or not NetGear would use the same CPU.
which controller - one that supports 3TB drives, is fast and reliable.
