CDStoneley
May 31, 2017Aspirant
New RN314 / EDA500 Owner concerned about Resync times
Long time ReadyNAS NV+ owner, just recently purchased a RN314 (used) and EDA500. Right now I have 4 x WD40EFRX in each chassis. Having just received new 4 x WD40EFRX for the EDA500 today, I insta...
- Jun 07, 2017
Wed Jun 7 2017 2:38:21 Volume: Volume ReadyNAS500 is resynced. ... Wed May 31 2017 15:57:24 Volume: Resyncing started for Volume ReadyNAS500. It finished. Eventually. The above can serve as a data point for 4 x 4TB drives, RAID 10 configuration, EDA500, on 6.6.1.
Thanks for those who suggested patience!
Jun 02, 2017Guru - Experienced User
If maximizing fault tolerance is the only goal, then RAID-6 is the best option. RAID-10 doesn't handle all combinations of 2-disk failures.
Resync speed on the EDA is likely limited by the eSATA connection between the NAS and the EDA.
Laserbait
Jun 02, 2017Luminary
I wish the RN31x series had some sort of SSD caching to offset the performance penalty of RAID6 though. How goes the rebuild?
