CDStoneley
May 31, 2017Aspirant
New RN314 / EDA500 Owner concerned about Resync times
Long time ReadyNAS NV+ owner, just recently purchased a RN314 (used) and EDA500. Right now I have 4 x WD40EFRX in each chassis. Having just received new 4 x WD40EFRX for the EDA500 today, I insta...
- Jun 07, 2017
Wed Jun 7 2017 2:38:21 Volume: Volume ReadyNAS500 is resynced. ... Wed May 31 2017 15:57:24 Volume: Resyncing started for Volume ReadyNAS500. It finished. Eventually. The above can serve as a data point for 4 x 4TB drives, RAID 10 configuration, EDA500, on 6.6.1.
Thanks for those who suggested patience!
hmuessig
Jun 07, 2017Luminary
For what it is worth my EDA500 with three 4TB drives took four days (96 hours) to resync/build. And the time estimates 'till completion improved significantly as it progressed. Have patience!
Also at some point -- if I recall at about 50% -- you should be able to look at the SMART stats for each drive in the array. But with a 314 the responsiveness of the management interface will be sloooow.
CDStoneley
Jun 07, 2017Aspirant
| Wed Jun 7 2017 2:38:21 | Volume: Volume ReadyNAS500 is resynced. | |
| Wed May 31 2017 15:57:24 | Volume: Resyncing started for Volume ReadyNAS500. |
- LaserbaitJul 25, 2017Luminary
Another data point to those that are reading this in the future, I did some testing with my RN316 on OS 6.7.5:
EDA500 with 5x 4TB Seagate ST4000DM000 in RAID5 resync took ~41 hours.
EDA500 with 5x 4TB Seagate ST4000DM000 in RAID6 resync took ~44 hours.
I'm also going to try 4x 4TB Seagate ST4000DM000 in RAID10, just to see how long that takes.
- LaserbaitJul 27, 2017Luminary
RAID 10 with 4 x 4TB ST4000DM000 in the EDA500 took ~34 hours
