zspradlin
Aug 12, 2016Follower
New to NAS
Hi there. I am new to the topic of NAS and have a couple of questions. Recently, a couple of months ago, My Windows PC fell victim to ransomware, Some data, photos/music/videos/etc, were lost and som...
Aug 12, 2016Guru - Experienced User
The NAS has antivirus, but I don't know if it would protect against ransomware (and it would be safest if you assume that it might not).
There has been some discussion on ransomware here from time to time.
If the NAS has enough free space, then the NAS snapshot feature offers some level of protection - letting you roll back to the older unencrypted files. But that requires that you keep the NAS < 40% full. Then when the files are encrypted, the old copies are retained in the snapshot, with the total storage staying well below 90%. At the 90% threshold, the NAS will begin deleting the oldest snapshots automatically, and of course those are the unencrypted files you want to keep around. It requires some discipline to keep the storage below 40%.
A backup that is not writable by the PC is probably the strongest option (and you should have a backup of the NAS anyway if you use it for primary storage). So you could (for instance) get a USB backup disk, and attach it to the NAS. Then run automated backups from the NAS shares to the USB drive. You should think about the backup pace - if you back up automatically too often, the encrypted files might propagate to the USB drive before you notice. Not often enough, then you lose more files that weren't backed up.
- mdgm-ntgrAug 14, 2016NETGEAR Employee Retired
The ~40% figure would be assuming the worst case scenario where all the files are encrypted.
If you mainly have huge files (e.g. multiple GB files) then ransomware tends to skip those, but rather focus on the smaller files such as e.g. music, photos, word & excel documents, video clips (that are smaller in size) that are faster to encrypt. However ransomware is constantly evolving so that may change.It's also worth noting that some use cases are more suited to using snapshots than others. So they may be appropriate for some shares on your NAS and not for others.
