Davidkent89
Jul 29, 2017Aspirant
New to this but having issues
Afternoon all. I’ve got a readynas 2120 handed down to me and am having trouble setting it up. I’ve done the full reset hold button 30 seconds etc and have successfully found it on raidair. W...
Jul 29, 2017Guru - Experienced User
You have at least one disk in the NAS?
If so, are the disk(s) formatted?
You can zero the disks or delete all the partitions, and then power up the NAS with the disks inserted. It should do a full factory install.
- Davidkent89Jul 29, 2017Aspirant
One drive installed.
Powered down and held the reset button, powered back on and waited 30 seconds for the second flash and it did its install etc.
Am i doing this correctly?
Thanks so far
ANd i've used the drive before with a caddy though it was used on my Xbox before.
Raidair will open the folder and lets me view it though, it seems empty.
- StephenBJul 29, 2017Guru - Experienced User
If you did the factory install, there will be a few empty shares. Is that what you see?
