Rabi
Aug 06, 2016Aspirant
Newbie - install a ReadyNAS 4 ULTRA
Hi There I got a Readynas ultra 4000 from my work because they do not need it. There is two disk in it. and two empty slots. I only have apple devices here at home, my router is a Time Machine...
Rabi
i will try that
but is it hard to install ... ? after
Aug 06, 2016Guru - Experienced User
The hardware manual is here: http://www.readynas.com/download/documentation/HM/ReadyNAS_Ultra_UltraPlus_Pro_HW_13April11.pdf
The software manual is here: http://www.readynas.com/download/documentation/UM/ReadyNAS_Home_SW_6June11.pdf
Your NAS ships with OS 4 (the firmware should be 4.2.x). It can be converted to OS 6 - not sure if that has advantages for using TimeMachine backup or not. Hopefully a mac user will chime in.
Well, that depends in part on what skills you have. We can provide advice if you get stuck.
One piece of advice up front: RAID is not enough to keep your data safe. The best way to do that is to have more than one copy on different devices. After you are up and running, you should also think about your backup plan.
- mdgm-ntgrAug 06, 2016NETGEAR Employee Retired
StephenB wrote:
Your NAS ships with OS 4 (the firmware should be 4.2.x). It can be converted to OS 6 - not sure if that has advantages for using TimeMachine backup or not. Hopefully a mac user will chime in.OS6 has a newer version of netatalk (the package used for AFP/Time Machine support) and has per user Time Machine. So there are some advantages, but Time Machine backups work fine with RAIDiator-x86 4.2.x at this time.
