norm470's avatar
norm470
Newbie Question on readynas Remote
Can I use readynas remote to stream movies from the nas to my tv from another location.? Thanks for your time.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I think you want ReadyDLNA which can be used to stream to DLNA/UPnP-AV clients
  • Norm470 - if you could be more specific in what your situation is. What model of ReadyNAS do you have and is it on the same network as your TV?
    Is the TV capable of receiving the stream directly or do you have another device in the stream to convert the stream to video output for the TV?
ProSupport for Business
