anna_arun
Jul 01, 2013NETGEAR Expert
NFS Path for Windows Application
Hi , I have to give a NFS path to my application to store data on to the ReadyNAS 516 . What is the default path to enter to access the path ? Tried /c/sharename ... Does not work . Had enabled NFS o...
mdgm-ntgr
Jul 01, 2013NETGEAR Employee Retired
Under System > Volumes in the Dashboard you will see the name of your data volume. The default name is "data". I think if you have enabled NFS on a share the path would just be "sharename" though.
