anna_arun
Jul 01, 2013NETGEAR Expert
NFS Path for Windows Application
Hi , I have to give a NFS path to my application to store data on to the ReadyNAS 516 . What is the default path to enter to access the path ? Tried /c/sharename ... Does not work . Had enabled NFS o...
mdgm-ntgr
Jul 02, 2013NETGEAR Employee Retired
Well you would be sharing the share sharename over NFS not the entire data volume, so I would try "sharename" (no quotes)
